Originally Posted by Ace23
Mark,
The spring rate may require an upgrade with the additional weight....maybe not just have to try it and see. What size diameter are the 385 headers? Cylinder head selection would impact the header selection......are the headers you have designed around the cobra jet heads?
The factory headers are a compromise at best and it looks like you are looking for every little bit so I suggest custom headers. Look at these:
Firefly Stainless Steel performance pipes have been designed
And you will need their side pipes as well as the factory pipes will be too restrictive with higher flowing headers.
