Old 06-09-2016, 09:04 AM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Default Thoughts on this Side Oiler for sale ?
What do you think of this 427 Side Oiler for sale, and price ?
A video link is below.
427 FORD FE Side Oiler Rebuilt Medium Riser Tunnel Wedge
427 FORD FE Side Oiler Rebuilt Medium Riser Tunnel Wedge - $9995 (Marysville) hide this posting
condition: like new
make / manufacturer: Ford Mercury FoMoCo
model name / number: Sideoiler
FORD 427 FE Side Oiler Cross Bolted Medium Riser with Tunnel Wedge and Matching C5AF-BC-BD Holley's. Complete High End Rebuild with Only the Best New Parts. The Specs are Below:
1970 427 FE Hydraulic Block. These Late Blocks are the Strongest FORD made and also were Hydraulic Blocks for better Lifter Oiling. This Block has No Repairs, Cracks or Sleeves
The Block is Bored .030 over and was Honed with Torque Plates.
Venolia .030 Dome Pistons
C5AE-C Std./Std. Forged Steel Crankshaft. Crank has Screw in Plugs
C5AE-C LeMans Rods with New ARP Bolts
C5AE-6090-F Medium Riser Heads with New Stainless Valves. Date Codes of 0A19 & 0B6
Lunati Billet Mechanical Roller Camshaft, Lift .588 int. & .593 exh. Dur. @ 50 256 int. & 266 exh.
Matching Lunati Solid Roller Lifters
HD Harland Sharp Roller Rockers with Solid Rocker Shafts
Vintage Accel Dual Point Distributor with Tach Drive
C8AX-9424-A Aluminum Tunnel Wedge FoMoCo Intake & Linkage
Matching C5AF-9510-BC & BD Holley Carbs Dated 853 and 853
Cobra LeMans Pent Roof Aluminum Valve Covers
TRW HV Oil Pump
Ford Motorsport Windage Tray
Steel Flywheel
Complete Rotating Assembly is Balanced.
This Engine was Running on a Engine Break in Stand for about an hour to break it in and do some tuning. Come hear it run. Here is a link to the YouTube video: [ame]https://www.youtube.com/watch?v=xEX_wW9ygrA[/ame] or just paste this into the YouTube site: v=xEX_wW9ygrA
Sound and Runs AWESOME
PRICE $9,995.00 CASH
http://images.craigslist.org/00101_7...Z5_600x450.jpg
Thanks,
Kevin
Regards,
Kevin
