I dropped $957 today for a set of four. Hopefully they will work. Special balancing on a Hunter Road Force balancing machine and a front end alignment will follow.
I will give a full report on how they compare to the Goodyear Eagle GT's. I plan to keep the rear tires as they still looked good. The front would vibrate significantly at 70 mph from the cupping. Either way, between the alignment, new tires, and balancing, these things should solve my problem as everything else underneath seemed tight on inspection.
Phil
