So Dan, did it work?
Here is my situation. I thought I had the same problem as you with my Toploader. I tightened up the tail shaft section but they were already very tight. now that I have the interior out including the tunnel,l I noticed the top is wet and it is seeping from there! I snugged up the bolts, they were not tight at all.I would like to install a new gasket. Is this as straightforward as it looks or is there a surprise waiting below?
Does anybody know the part number for the Gasket I need. Also a Torque spec for the bolts?
Thanks...Dave
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
