Originally Posted by cdnus
David
I used the same type as David Kee sells. Would have to look for exact location did it so long ago. I believe it was top side, Half way between speedo hole and rear tailshaft bushing.
Craig
Just found it on the site. They have a 15.00 minimum order, so I added a rear seal and output shaft plug to get to the minimum. Their cheapest shipping is outrageous! They want 21.00 bucks for their cheapest option. These things could be put in a USPS mailer envelope for pennies. I might call them later to explore that option.
So, if it leaks out of the top cover breather, why is it not going to leak out of the newly installed tail-shaft breather? I would think it would leak easier from there due to the lower location and gravity vs. the top cover?
