Originally Posted by Gregg(What's his name)?
Lance Smith at Craft performance or Tony Carry in the NYC area. Both get high marks from Peter.
Thanks
Originally Posted by patrickt
Absolutely. If I lived in NC, that's who I would go to.
Well that's two votes, actually, for some reason I feel compelled to believe Patrick's vote is worth two votes of a common person, or maybe not?
Originally Posted by DanEC
Back when I had my engine built (about 2010) Keith Craft was charging about $500 more for a 428 core vs a 390 core - not a whole lot of difference but the market may have evolved since then. If you want maximium cu in with a stroker crank the 428 will go a bit bigger due to it's larger bore to start with. In the 445 cu in range you can work with a 390 and 4.25 stroke or a 428 with a 4.125 stroke. If you save the $500 on the 428 block and put it in a set of aluminum heads on the 390 instead - you will no doubt be HP ahead in the end - can go with a bit more compression and better breathing. Lots of combinations to choose from.
Hmm, +$500 is not bad (until that happens about 6 times). I would prefer a 428.....i'll give them a call today.
More to follow...thanks
