Old 06-25-2016, 09:17 AM
GLS-BDR226 GLS-BDR226 is offline
Cobra Make, Engine: BDR, 302
Agree with Blykins, the BDRs have had heat issues with the hydraulic clutch system which causes problems with the master and/or slave. There's a heat shield that mounts to the bottom of the master that helps. Also yearly flush and bleeding with high temp brake fluid (Wilwood) helps. The clutch is accessed through the bottom, not thru the tunnel like an ERA. Good luck.
