lighter socket
The polarity might be reversed on the lighter socket. The cig lighter element doesnt care which connector is grounded. The cell phone does.
Try reversing the the ground and hot wires if you can. The body of the socket might use the mounting surface as ground, then you cant.
Good Luck.
The Nut.
Enough is enough. Too much is just right ( C.S )
