Originally Posted by jimbo01
I ordered a slave cylinder from Rosehill Performance and the push rod from him. The pushrod is adjustable allowing the proper adjustment to the clutch via the through out bearing. I also installed a remote clutch master cylinder from Summit (cheaper than form Backdraft) and an aluminum reservoir and had a stainless line made by BAT in Sarasota, FL. I send the the rubber line and he made a AN3 stainless line with the correct fittings. Took a little work but now my problems seems to be over.
If you can please post a couple of pics and the PNs you used. It will def help me down the road...
Thanks.
I'm in Ocala from time to time.
