Hi Dan - I'm not sure if I articulated clearly - I meant that normally, the axes of the yokes on either end line up parallel in the vertical plane when the shaft is laying flat on the floor as in the pic above. On mine, if the shaft is laid flat like that the yoke on one end would lie flat but the other, instead of also lying flat, would be twisted about 30 to 45 degrees. On one shaft this is a lot more pronounced than the other.
Tropical Buzz
