This is the damaged left side right after I dropped the assembly. The white arrow shows the bent LCA and the green arrow shows the misalignment of the half shaft yoke ends - the outer yoke appears to be rotated counter-clockwise in relation to the inner yoke which would be consistent with a twist caused by forward acceleration. The other side is the same, reflecting a forward motion twist. The shafts are shortened stock cast units, not tubular. the hub carrier is broken on the bottom, allowing it to bend towards the front of the car.
Tropical Buzz
