Thread: WOT too Lean
  #100 (permalink)
Old 07-01-2016, 05:54 AM
blykins blykins is offline
You would find a lot more throttle response and maybe even some more performance from a 650-750 sized carb.
You're running almost the same size jets that we run on our 1050 sized carbs on MUCH bigger engines. When you have to do that, it should be a clue that the engine just doesn't have enough signal to use that carburetor correctly.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
