My TKO tremec was leaking generous amounts of
oil out of the breather at the top front of the trans case.
I removed the small cap from the breather and then connected a 2 foot long hose to the stub on the case. I looped the hose up and around a bracket on the firewall, similar to venting the rear housing. A 30 mile test run shows no leaking at all.
Crimped cap on breather can be pried off, and contains a spring and plastic disc to cover breather hole.
Now I have to power wash bottom of car to remove trans
oil and dirt.
