Originally Posted by Mark IV
The T56 Magnum is NOT the same trans as a Mustang. The Mustang uses a Getrag box, the MT82, not a Tremec.
Alignment of the pushrod is very important, you want minimum in-out/up-down movement when activated. This is hard to achieve as the clutch arm swings in an arc but it can be held to a minimum with proper design.
