Old 07-05-2016, 07:50 AM
spdbrake spdbrake is offline
Top bleeding the system is pretty easy and you can do it alone.
You'll need a Rubber stopper to fit the reservoir opening. A #10 stopper works on the Willwood master cylinder.
Preferably use EPDM rubber as it is compatible with brake fluid but any will do since it is a momentary contact issue.
Using a brake bleeder hand vac pump connect to the stopper you placed in the reservoir neck with a short piece of hose.
Pull a vacuum with the pump and maintain it for 1 minute (max vac you can achieve).
Release the vacuum and pump the clutch pedal full travel 4-5 strokes.
Repeat the vacuum/pumping cycle 5-6 times on a empty system will typically bleed it fully.
EPDM Rubber Stoppers: solid, 1 hole & 2 holes | WidgetCo
MossMotors.com - Restoration Parts And Accessories For British Cars
