I have the DreamCar mirrors on my SPF. I love them. One of the biggest advantages is that one doesn't look through the wind wing to utilize the mirror, thus no distortion. By being mounted inside the wind wing on the passenger side, it is easy to lean over and make an adjustment, especially after my bride has been in the car and adjusted them so she can see what is behind us. I had the RayDots before and adjusting them was a pain, although only done rarely. The DreamCar mirrors are a little larger in diameter and are slightly convex.
Since both styles are mounted on the windscreen, there is some minor bounce when the windscreen bounces and flexes. The bounce is about the same for either style.
You need to check with the seller to make sure the mounts will work for your car.
Tom
