  #128 (permalink)
Old 07-07-2016, 11:13 AM
patrickt patrickt is offline
Neutral
Is there a dyno sheet on this one ?
That 445 & 453 both probably feel pretty much like mine. My 447 has a little shorter stroke, slightly fatter bore, a few tenths more compression and a few degrees more duration, but a little less lift, and little more lobe separation. Unless he sent something to you that was broken, which ain't gonna happen, you would be quite pleased with either. I think it's now officially time for you to write a check to somebody, otherwise they're likely to assess you as being more of an irritant than your business is worth.
