Old 07-11-2016, 01:34 PM
66gtk 66gtk is offline
Thank you Patrick. I have that same document and it's what is at the bottom that concerns me:
Upright Modifications:
Cut the original caliper mounting ears off the upright (see illustration on the next page) with an oxy-acetylene cutting torch. The template shows the approximate areas that must be removed to clear the mounting ears. Flip the template over for the opposite side. Finish off the cut areas with a grinder. Before you paint your upright, check the fit of the bracket and caliper.
