07-13-2016, 05:42 PM
NY
Cobra Make, Engine: SPO 963, 351W
Originally Posted by patrickt
Shoot Blas a PM and ask him. He knows more about the SPF wiring than most, and has wiring diagrams as well. As I recall, certain SPF cars took the source voltage for the voltage regulators from either a bad connection or a spot in the circuits that did not accurately reflect the system voltage. But that's just from memory, and I don't own an SPF anyway. And that may, or may not, play a factor in your problem. If you had that problem, though, I would fix it first. Then, if you still have your charging needle goofy behavior, we'll lead you through the diagnosis. It is not difficult.
ok, will do. Thanks for the guidance!
