Thread: fuel tank vent?
Old 07-18-2016, 09:02 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
The gas cap has a tiny 1/8" hole in it. If you pull the gasket off the inside of the cap, it is like a tiny maze under it that the grooves are very very shallow. Mine plugged up causing pressure in the tank. I think that was one of my problems after running the car and shutting it down with pressure in the tank?!?!
Just got it all back to gather so I can confirm if its all good now. I drilled 3 more holes in the side of the cap, and put a .003 stainless shim under the gasket so it wouldn't plug up the grooves.
Scott
