Originally Posted by tamanaco
Nice list of parts! Thanks!
Do have a questions. all are solid mounts, except the diff mounting is Poly...the reason you selected this poly mounts for the diff is?
Thanks, Bill...
The entire suspension is without rubber or poly as I want to eliminate as much deflection as possible. This makes the handling much more predictable and allows me to pull higher G's... We pull around 1.3 G's when turning and around 1 G accelerating and braking. And we change directions a lot. An autocross is basically a road course without the straits....
The poly diff mounts are there as I want a weee little bit of deflection there so as to slow down the shock load transfer to the ground under load and back to the diff when you release the load.
Kevin....
