Clutch Problem
My car is Backdraft 818 with a Roush SRTW 427 engine and TKO 600 transmission. When the car is cold the clutch disengages perfectly. When it is hot it will not completely disengage and it is hard to get it into reverse. It will go into the forward gears when hot but not easily as when it is first started. I flush the clutch regularly and as far as I can tell clutch travel on the slave cylinder is adjusted properly. Any thoughts on what else I could check?
