I just went through similar issues with another BD. It was the slave cylinder and clutch adjustment. That is where I would start. After that, the TKO 600 transmission shift fork nylon inserts can be the a problem as well. They are not hard to change, but it may require the transmission coming out on the BD. I would go in this order, adjust clutch, then slave cylinder, and then trans.
Phil
