Originally Posted by scootter
The gas cap has a tiny 1/8" hole in it. If you pull the gasket off the inside of the cap, it is like a tiny maze under it that the grooves are very very shallow. Mine plugged up causing pressure in the tank. I think that was one of my problems after running the car and shutting it down with pressure in the tank?!?!
Just got it all back to gather so I can confirm if its all good now. I drilled 3 more holes in the side of the cap, and put a .003 stainless shim under the gasket so it wouldn't plug up the grooves.
Scott
Thanks, I found that tiny mouse maze under the gasket, kinda crazy if you ask me, but it works for me.
