DV:
I would love to reccomend a cam, but this depends on the porting of the heads. Numbers around 255 - 265 @ .050 duration and .600 - .650 lift will be about the limit for a high end street engine. The trick is to get the "combination" right for the heads.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
