Originally Posted by FUNFER2
A hydraulic roller will be less tolerant of higher spring pressures, but guys seem to want high pressure with both double springs. Either way, what are the things you can to them and not to bend, snap and even float the valve at high RPM's ?
What are the safe guards for the FE, including not floating valves ?
Should just put a Chevy in, a lot cheaper & easier.
Everything as light as possible. With a 2.20" titanium intake valve, titanium retainers, light weight lifters, and the right lobe I turn 7500 rpm with 155/410 springs. That's not to say an FE will turn that with the same parts, as Brent said, the FE stuff will be heavier.
Edit: The LS7 also has light weight and strong rocker arms which helps too.
