Ok, just got a call from the shop. At least one broken valve spring. He said these springs are only good for 6000 rpm and up to 600 lift. I need springs for 7000 (I run up to 6000) and 650 lift (I have 610).
Any spring recommendations? I will probably need new retainers, etc. Anyone have a good site where I can get info about spring size, height, shims, pressure, etc. Also info about how to correctly setup everything?
It's weird, AFR says the stock springs that come on these AFR 195 renegade heads can handle 7000 and 650... Maybe they changed them at some point.
