  #133 (permalink)
Old 07-26-2016, 08:51 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
How many broken springs did they find?
They took the driver's side valve cover off and found "at least one" broken inner spring. I don't think they did any more than that. Once he found the broken spring he called me to see what I wanted to do. The labor alone on replacing them all was quoted as $1k. He was going to go"talk to the machine shop" to see what springs they recommended. I don't know anything about their machine shop, and I trust Brent, So I just told him to put it all back together and I would do the work myself.
Originally Posted by DWRAT View Post
AFR 195 Renegade heads are rated to 7,000 rpms per ARF specs.
I'm betting you have a different problem causing your misfiring.
That's if AFR used the same springs when I bought these heads as they do now. Yes, the current springs are rated for 7k, but I read on other sites that previously the 7k springs were an option, not standard. They have since started using the better springs as standard. I don't know which springs I actually have.
The shop guy said a spring was broken. He said they were only rated to 6k and were weak. I didn't ask how he decided that. Either way the springs need to be replaced if there is a broken one.
When I get it back tomorrow, I'll see if I can figure out what springs they actually are, then find their ratings. They should be painted with a color stripe for identification.
