I will be the first to admit that I'm no expert but the photo of the front suspension appears to be shown at full droop.
I would want the suspension to be placed in that position at full static load, if not actually slightly lower at the outboard end so an imaginary line drawn through the lower inner pivot and the outer lower ball joint is horizontal / parallel to the ground when loaded.
Someone earlier stated it looked odd and I have to agree. Best to check the geometry now before going further and having to undo your good work.
Ricky
RF GT40, Ralt RT5
