Thread: Took the leap
  #30 (permalink)
Old 07-27-2016, 06:34 PM
Antny's Avatar
Antny Antny is offline
Cobra Make, Engine: SPO 963, 351W
Cool, the video should put this issue to rest one way or the other.
Who's spindles are you using? If not Toyota Supra, are the ball joint mounting points the same dimension as the Toyota? If not, the geometry will not be the same. If they too are from the same year Toyota Supra, then the geometry SHOULD be fine and you'll be golden.
