Thread: 429 CJ Worth?
Old 07-31-2016, 04:29 PM
CriticalMass CriticalMass is offline
Cobra Make, Engine: ERA #164 427 Med Rise Side-Oiler, 4 Speed Toploader
Default 429 CJ Worth?
I see plenty of posts asking this question (not just on ClubCobra), but reliable answers are hard to come by. I don't know if I'll get better results, but I thought I'd try:
When my father was preparing to build his kit back in the 80's he picked up a 429CJ and rebuilt it in preparation for installing it in the car. After the engine was complete, but before it was installed, he found a good deal on a 427 sideoiler and chose instead to install that in the car. As a result, the 429CJ sat in his garage, and now sits in mine, for what is going on 31 years. It's a shame for it to sit unused, and I don't have any applications for it, so I'm looking to sell it. I really have very little idea of what to price it at which is what has prevented me from getting it sold. I want to avoid asking too much but also want to avoid getting taken because I don't fully understand what I have here.
I have what I believe to be comprehensive receipts and pulled/inspected the top end to verify that the receipts are accurate. Here are the details:
Block Casting Number: D1VE-6015-AA (bored & honed .030 over)
Heads: TFS square exhaust port aluminum cylinder heads (ported & polished/88CI)
Intake: Single 4-barrel high-rise manifold (Holley maybe?)
Valves: Manley 2.3" intake/1.88" exhaust stainless steel
Pistons: TRW L2366R030 forged aluminum flat top
Camshaft: Competition Cams 34-331-4 (.3063 lobe lift, .530 valve lift, 280deg duration)
Lifters/Rods: Competition Cams CC-832 hydraulic flat-tappet with heavy-duty 3/8" rods
Rockers: Norris NPR175 stainless steel roller rockers
Oil Pan: Milodon deep sump, reverse
If any other component is critical to the value of the engine let me know, I should have info on it. All the machine shop work you would expect from a rebuild is documented. Stored with all passages masked off, covered, and without compression on valve springs. Internals got regular coatings of oil and everything looks like the day it was machined. No rust anywhere except externally on the crankshaft drive flange (will clean up easily).
From the documentation I have it looks like all the parts and machine shop labor totals $6850 in 1985 dollars, but I'm not sure how things have retained their value. Also, I assume that any buyer (knowing that the engine has been sitting for 3 decades) will at least want to inspect the bottom end if not disassemble and clean/re-lube everything, so I assume this thing will not demand tested/dyno'd prices. However, it should not require any machine work.
I would really appreciate any input. If you need any other info, let me know.
Thanks.
