The 275/60R15's are too big for the front. That is the size that SPF puts on the rear as standard equipment. I have 255/60R15's on the front of mine and I certainly wouldn't go any larger. Also, I suspect you will have rubbing issues with that size rear tire. I use to have the MT 12-28x15 SR's on the rear of mine and although I was able to run them, I couldn't get the rear ride height down to where I wanted it without rubbing issues. I now run the MT 295/55R15 ST's and they work fine.
Ted
