Old 08-27-2016, 07:27 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by mdross1 View Post
Cannot find the info I have read before somewhere about removing fender mirror and a small plaque or cover the hide the screw holes. Anybody remember seeing that info ?
What mirror do you have now?
Does it have a Phillips head screw at it's front most tip?
if so, remove the screw and take the mirror assembly out.
Next take the small nut off the stud that is behind where the mirror is and lift that assembly off the mounting base.
At that time you can ascertain which mount you have, and what may be done to eliminate the holes left in the body.
Depending on the color, a good bodyman may be able to fill the holes and touch up and color sand the touch up for an almost imperceptible repair.
So, with that said, what color is your car painted? perhaps attaching a picture might help.
Bill S
