Old 08-30-2016, 02:56 PM
Steve Gallegos Steve Gallegos is offline
If you want shade, I made a bemini top for my Backdraft using the back frame for the soft top and bows I bought from ERA, you need side clips also to clip the front bows to. You also need a groved top rail on the window with a open piece in the middle of the frame, about 1.5 inches long,to put the pins in that are on the front bows that hold it down on the frame. With a little modification using 2 1"aluminum strips bent in a bow across the top from driver to passenger side it works great. No flap, It can handle speeds up to 80mph.
