Old 08-31-2016, 12:20 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by LMH View Post
Yes, that's true. It's also the way Ford did it on the 03/04 Mustang Cobra in which the CV joints and differential were used from the factory. I've never seen an outer CV joint break but I have seen a couple inner joints break.
The next weak point is the production differential cover. The production cover is just not strong at all.
Originally Posted by vatdevil View Post
Most important improvement is replacing the stock diff mount bushings with solid. Wheel hop is real hard on halfshafts
So you guys are advocating just swapping the gear only and going with the solid diff mount bushings from someone like Craig's Cobra?
Also is our 8.8 diff the identical diff that was used in the 03-04 cobras? If so I know where a brand new 03-04 cobra diff is......that would give me the 31 spline setup and all I would need to do is change the gears. I could sell my current diff.
