Originally Posted by GH427
Hi Modena, interested how you measured up the positions of the holes for the quick jacks before you drilled them.
George
Hi, the "bolt" is currently a piece of threaded rod which I'm going to replace with a socket head cap screw. I bolted on the threaded rod inside and used it to mark the inside of the body, then drilled a pilot hole from the inside and then used the hole saw from the outside.
