Old 09-06-2016, 10:08 AM
Igofastr's Avatar
Igofastr Igofastr is offline
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
Originally Posted by kbmyers View Post
The hose to the air cleaner is going to be tricky since I'm running a Borla induction system with 8 velocity stacks.
I'll check with ERA to see if the MSO saying it is a replica of a 1966 will be a problem.
So with a PCV system, does one valve cover still have the breather while the other has the PCV valve with the hose?
Thanks,
Kent
You'll need a "closed system". So "yes." The PCV will be plumbed to the intake below the carb (ie to the intake manifold), and the other will be plumbed to the intake above the carb, usually tapped into the air filter.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
