  #154 (permalink)
Old 09-08-2016, 01:42 AM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
I believe the only reason the GT40's get away with plastic side windows is because they are permanently affixed to the door, whereas a sliding side window should be E-Dot compliant or laminated, so you may need to look for something similar to the curve you require and see if you can get the window trimmed to size (this can be done even with a laminated glass side window) but may be expensive..
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
