When I first installed the top it was taut. Has stretched a little. Immediately even when taut the windshield was moving or flexing if you will. This is without side windows in place. I installed four 3/4 inch wide by 1/2 inch thick Baltic birch plywood stringers. ONe end is at approximately 50 degrees so it tends to wedge itself into the top framework. Used Velcro on windshield end and then thin metal straps on other end to the bow. Stabilized the top and windshield completely. Top speed so far is 100 and working great. Going on a run on Sunday of about 180 miles. Will report back of results. I want to drive without the side windows. The top is for sun and wind that beats us up on long drives. Gary
