Originally Posted by HI Cobra
I built mine in 2000 and wrapped the headers. Later I got Don's side pipes
that eliminated the restriction issue and had them ceramic coated, along
with the headers. No damage from heat anywhere, so either way worked for
me. I have heard stories about rust from wrapping but when I pulled the
wrapped pipes to change for the new ones there was no rust or damage that
I could see, this was after about 8 years or so.
HI cobra,
Thanks for the info, I'm also changing out my 1990 factory mufflers to classic chambered 30" mufflers and turnouts. The elimination of backpressure and ceramic coating should help dramatically with lower upper header tube temps.
I looked at you gallery and have to say that I really like the aluminum plate you installed across the top of the firewall and hood latch area, looks great! and also hides some of the wiring, etc.
