Correct Greggy. No Speed in the ECU, but it is definitely getting the signal from the (stock) T56 vss as I piggy back off that to the speedo direct and it works no problem. There is no getting the reverse lockout working if I cant get a speed in the ecu - at the moment I have a little overide switch on the console. Not a biggy but one of the little niggles Id like to sort out eventually.
