09-22-2016, 07:10 PM
ct
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by undy
You have two accelerator pumps, one for the primaries and another for the mechanical secondaries. If your secondary pump's actuating arm is adjusted wrong and you're not getting a shot of fuel as soon as the secondaries start to open then you'll get an initial bog. The fuel slots in the venturies don't pick up the job until after the accelerator pump has shot its w@d. It's not at all an uncommon problem.
Well, it is not that anyway, it is adjusted correctly. any other thoughts?
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
