  #32 (permalink)
Old 09-24-2016, 05:56 AM
blykins blykins is offline
As promised....
Would have had the heads assembled but I was out of the valve spring locators I needed.... The heads are primered and painted and I'm waiting for the warehouse to send me the parts I need so I can assemble them.
Everything has went together pretty much without fuss, with the exception of the oil pump pickup. I used a Canton oil pan with Alan's build and the pickup that is recommended for the pan showed 9/16" of pickup clearance when I mocked it up and measured. Luckily, I had a Moroso pickup on the shelf that showed a more desirable 5/16" when I tried it. So, it has a Canton pan with a Moroso pickup. I also had to dimple the oil pan around the rear rail so that it would sit on the block without contacting the rear main cap bolts.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
