Thread
Lykins Motorsports 427FE Build, Alan Carter
41
permalink
09-30-2016, 06:43 AM
blykins
I run the cam timing pretty advanced on a lot of my engines. This cam was ordered with a 110 LSA, on a 104 ICL. It degreed in at 103.25. When we run that advanced, you can really see how piston to valve clearance is affected. The trend is that when you advance cam timing, intake valve clearance decreases and exhaust valve clearance increases. As you can see in the next two pictures, it's very apparent: intake valve clearance was .100" + head gasket thickness, exhaust valve clearance was a whopping .300" + head gasket.
Valve springs are set up at a nominal 1.900" install height. Valve spring pressures are tested based on install height, full lift, and coil bind.
And if you've never seen a factory MR intake port that approaches 320 cfm, then here's your chance....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
06:46 AM
blykins
View Public Profile
Visit blykins's homepage!
Find all posts by blykins
