  #47 (permalink)
Old 10-02-2016, 08:03 AM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
As promised....
Everything has went together pretty much without fuss, with the exception of the oil pump pickup. I used a Canton oil pan with Alan's build and the pickup that is recommended for the pan showed 9/16" of pickup clearance when I mocked it up and measured. Luckily, I had a Moroso pickup on the shelf that showed a more desirable 5/16" when I tried it. So, it has a Canton pan with a Moroso pickup. I also had to dimple the oil pan around the rear rail so that it would sit on the block without contacting the rear main cap bolts.
This build is really nice, I'm jealous.
Back to the Canton oil pan. Are you running the RR pan or the standard T pan? Wind-age tray? This winter I am hoping to finally switching out my regular pan for the RR pan with the dipstick on the right (Passenger) side.
Also not aware of any dimpling that needs to be done. I installed a Canton pan on my last 428 with no issue. Is the 427 different?
Along with my oil pan switch, I will be removing anything with a gasket because I am leaking oil from everywhere. A real ugly mess! Everything has been sitting on a shelf for three years now...LOL. Just not enough time!
Dave
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
