Thread
Kirk! We're under attack!! Suspension help.
102
permalink
10-08-2016, 07:05 PM
C5GTO
Panhard bar pics
Originally Posted by
rbgray1
Joel,
Does a 4 trailing arm setup benefit from a panhard bar?
Can you send me a pic of your setup? Would be very easy at this point.....just not sure Panhards and 4 trailing links go together.
I do know you want the panhard as long as absolutely possible, to create the largest arc possible.
Ok, I got a chance to put the car on jack stands and take some pics of the Panhard bar setup. The Panhard bar on my car is 33.5" center to center from pivot points. I've got a 9" in my car but the same setup should work on an 8.8". There's a tube running from the opposite side frame rail to the frame side mount to keep it from moving/flexing. The Panhard bar has about 3/8" clearance with the back of rear end housing and extends just short of the shock absorber. The side connected to the rear end runs under the frame rail.
I hope this helps
Thanks,
Joel Heinke (early 90's CRL Cobra)
C5GTO
View Public Profile
Find all posts by C5GTO
