If you run the filters it will flood the car under acceleration. Air too restricted...
You can use larger screen mesh, I just go naked.... Full on Weber...
Was that your issue, stalling under acceleration?
Also, cannot see but you need to keep fuel psi at 3psi. Webers do not need the fuel that a carb uses.
