Originally Posted by stephen low
AVO thank you for the comprehensive advice.
Just on point 1, do you mean measure the full distance between where the suspension would be at either end of maximum movement?
Or something else?
Ta
Steve
Steve, measure the full distance between full bump (fully compressed) and full rebound (fully extended). However, there can be some practical issues on fully extended. It can be that in normal use, you would never get to that maximum length. You may need to get some incidence from the suspension designer or an expert in the use of the vehicle
