Thread: turn signal
Old 10-13-2016, 09:58 AM
Quentin Z's Avatar
Quentin Z Quentin Z is offline
Cobra Make, Engine: Backdraft #272, 351W
I bought one off eBay for $50. Same POS, but a hell of a lot cheaper. I did have to remove the key (not sure if that's the correct name), dremel out the center to make it fit and cut the old plug off, splice and reuse, but it wasn't too bad. The wires were the same color, and I just used butt connectors. Also was able to rotate the stalk to the left now. I still need to punch the column a bit and reset the screw to keep it from rotating, but i'm lazy. It's here if you are up for it:
Turn Signal Switch Fits VW Ghia 1966 1967 CPR141953517F KG | eBay
