Thread: Lsd or not
Old 10-25-2016, 10:56 AM
cycleguy55's Avatar
Originally Posted by Jaydee View Post
Would it be true to say , that if you floored it going around a corner it is less likely for the rear end to let go if both tyres spin with a lsd, opposed to the inside tyre spinning letting you know to slow down with an open wheeler?
JD
If you floor it and break both tires loose the rear end will come around faster than you can say "holy s**t!" Some drivers are quick enough to counter steer and catch it, but many of these incidents have resulted in damaged cars and bruised egos - or worse.
Brian
